Left High Beam Not Working 09 GL1800
Aug 22, 2020
4
9
Dallas Center
Scott
Anyone familiar with the wiring of the high beams on a 2009 gl1800? Had the left bulb not working so went to change it out and the new bulb didn't work either. So, I checked the voltage with high beams on and appears I have an issue in the wiring. The right high beam works just fine.
If you do not find any corrosion on the wire connectors and the left bulb has a good ground, you could install a jumper wire from the right light wire to the left light wire at the bulb connector.
NCTriker
