Truckdogg4
10+ Posts
I have a 2021 Goldwing CSC Trike. The bottom trunk button quit working. Any suggestions?
I have a 2021 Goldwing Trike. The bottom trunk button quit working. Any suggestions?
Most of the time there's a cable under the seat you can pull to open the trunk looks like a throttle cable with no covering on it .
I have just acquired a CSC Volusia trike. Problem is there is no key fob, which as I understand wasn't working for some time and then lost. I have the cable but it isn't opening the trunk and I'm pulling pretty hard at it. I've got to get it open.
any further advice is appreciated.
Thanks .
Thanks .
You sure your FOB is close enough to the receiver........it can be touchy as the CSC Trike kit install moves the bike's receiver to a less than optimum location. I moved mine from the location the installer put it, and it works so much better now.
Maybe try holding the FOB up close to the underside of the Goldwing trunk to see if it works?
Did you get a response on the location of the trunk receiver placement? if so, where is it??
I have a new 2024 CSC Encore Kit, twice now in the last week my lower trunk has not opened when pushing the button. I see guys talking about a pull cable under the seat, I have looked and for the life of me cannot figure out what cable they are referring to. Bigger question is why is it even happening in the first place
