Hello,
I have a 2013 Ultra Limited with a Roadsmith kit installed when new. I just accumulated 50,000 miles. I had a wierd squeeling noise when doing a hard left had turn at about 15 mph. I replaced the front wheel bearing, rotors, pads and front tire. Afterwards the noise is still there, took trike to local HD dealer, they rode it and said it was probably the neck bearings, and for $1475 they would rebuild the forks and replace the neck bearings. I took it home and removed the forks and took them to an Indy shop I have used for years, I will lube and adjust the neck bearings and replace if needed. I accidently nicked the tubes very slightly but I may have to replace them as the nicks are in the seal area. So my question is, if I need to replace them, wondering if 2 inch longer tube would be better or worse for the trike. Roadsmith install an easy steer triple tree when new, probably a 4 or 5 degree rake, not sure. Just wondering the effects if I lenghten the forks. thanks in advance, Kim
