Front Brake Master Cylinder
Nov 28, 2024
104
164
Shropshire, UK
Brian
The front brake master cylinder on my GL1500 has a piston bore of 12mm designed to operate a single disc, does anyone in the USA produce a custom replacement looking like the original but with a 14mm piston bore which is for twin discs. I have looked at other Honda models with twin discs but the 'masters' do not match the original and I don't want odd looking kit on the trike.
I did research having mine bored out to 14mm but was advised against this by engineers as the thinning of the moulding where the piston fits would be very much weakened. I did buy a 'master' off ebay exactly like the original advised as 14mm piston but when it arrived it was actually 12 so sent straight back, found out later it was made in China. Anyone know a solution to this?
Left front is usually coupled with rear calipers on the trike, gives a far better brake and front brake is hardly ever needed
