No rear suspension adjuster knob
Sep 18, 2024
37
32
Tacoma,WA
Dirk
Just bought 2022 TG and went to check suspension load setting. Removed seat and there is NO adjuster knob. Thoughts? Are these standard or optional components when ordering bike?
Thank you for your input.
Dirk, for sure the stock Harley shocks have been replaced, if you bought from a HD dealer perhaps they have the service records and could tell you. I doubt they would give you the name of the previous owner to contact but you can try.
Thanks Z. I'll call them tomorrow.
Take one of the wheels off and look to see if you can see a coil spring over the shock. If so , you might be happy, just needs to be adjusted to your weight. I hope I’m right for you.
NGU, thanks for the suggestion. I will check it out. Thanks
wzejda
