Passenger Footpeg for 2018 GL1800 CSC Trike
Sep 17, 2021
15
14
Liberty Township, OH
Fred
I ordered a set of Goldstrike Passenger Comfort Pegs and they will not work on a CSC trike. I had called Will at CSC befoe I ordered them and he said he had an adapter kit for them. I came to find he had confused the passenger footpegs with the driver footpegs which is what the adapter is for. The issue as I see it is that there is a huge bolt head under that covering where the plate fastens that is obviously part of the CSC trike.
I called Kuryakyn on their Omini Passenger footboards and they seem to think that these will work on my trike. Has anyone used these on a trike similar to my 2018 GL1800 CSC trike? I am trying to avoid ordering the wrong thing again.
Thanks in advance for everyone's input.
Fred
I have a 2021 CSC conversion. The Omni floorboards will only work if you use risers as well. The Omni floorboards by themselves will hit the fiberglass body near the exhaust. You need to also use the Show Chrome risers and raise them up. I use the lowest raised location and it clears the fiberglass body. Here is a link to the risers.... Show Chrome 52-961E Goldwing Passenger Floorboard Riser Set
You can seen the risers in my pic below. You can also see where the rear portion of the floorboard would hit the fiberglass body near the exhaust without the riser.
I'm curious, what is this adapter kit that CSC sells for the driver pegs and what does it accomplish?
