Post Your Honda Trike Pics '2017 & Down
It would require basically replacing the whole front end. Triple tree, forks, fender, wheel, etc... And I'm not sure you will be able to find one as the EML is mostly available overseas. Add on that the most recent GL1500 was last produced almost 25 years ago so many aftermarket parts are no longer available.
Eurowing USA had a similar setup but nothing shows up on their website now and not sure if they offered it outside of having a full conversion done. Hannigan also had their 180 front end. It was a complete replacement of front end and a custom wide wheel. Theirs used a very wide 180/65R16 motorcycle tire but I'm guessing probably could also possibly use a car tire instead. But again, not available for GL1500's. And the Hannigan 180 front end would start at around $3500 not including labor.
Luckily I don't need to do anything other than a realignment of the forks to set bars
Going to fit some new rubber
I've never found what I wanted close by when I was ready to buy. Closest I ever got was Yamaha/Hannigan that was triked at low mileage and the owner passed before he put 1500 miles on and was 30 miles away. It was about 4 yrs before I pulled the trigger and bought my current ride. Both mine have come from Papa.
