Has anyone installed a CB on a 2024 Tri Glide Ultra?
The 2024 TriGlide has the GTS radio (same radio since 2019). So, if you have the modules, it can be added.
What I don't know is - did Harley install the cb line to the trunk. If not, you will need to put that in.
Good luck
As die hard a CB user as I was, I installed it on my 21 and have barely touched it. I am thinking of going Bluetooth but not now. I am curious as to if all the components are installable on the 24, I don’t see why not.
As die hard a CB user as I was I installed it on my 21 and have barely touched it. I am thinking of going Bluetooth but not now. I am curious as to if all the components are installable on the 24, I don’t see why not.
I too installed the CB on my 21. When we travel with the group, we use it. A number of folks are going to Cardo - and I already have a backup set pf helmets with Cardo.
Notgrownup - do you use carplay or AA? Not meaning to alter this thread, if you are using one of these, when connected to AA or carplay and you hit the transmit button on your CB, do it disconnect?
I don’t use either yet
Thanks - I have found that using this for my maps is very useful.
We just got back from Milwaukee - Harley Homecoming. While there, I set up at about 6 AA or carplay functions for guys that were traveling. Not many folks know they can display their maps on the GTS screen.
TYhis also updates automatically on google maps or waze - so you don't have to buy the updated Harley maps.
Can it be flashed? Have the 76000188 module and 71500130C r/h switch.
Yes, I installed on my 2024 TG. The CB system I purchased is p/n 76000486A but the part you mentioned (76000188) is I think just the CB module. The part I got includes the module and the mounting bracket. The CB system for the Rushmore bikes has been discontinued and no longer available from H-D so I fully expect that the wiring for the antenna in the tour-pack will soon be eliminated. That was the first thing I checked before I purchased the 2024 and yes all the wiring is in place. Just need the set screw for the antenna and the antenna itself. Dealer must flash the BoomBox for the CB to work.
I’m interested in that. I’m technically challenged…lol
While you might be technically challenged, I know you are indeed mechanically inclined.
OK - are you android or carplay. Once I know what you are using, I can provide the quick steps. Also, if carplay, do you use a wired headset?
CB works fine with CarPlay active. I listen to Pandora and sometimes an incoming transmission will cause playback to pause. Not always just sometimes. Other than that no issues.
Thanks - I posted a concern earlier. When I have my maps up (google maps) and the CB is on, I can hear all of the transmissions without any problems.
However, when I key the mic to transmit, google maps disconnect and it has to reconnect.
To add to that, when I actually key the map, all works well. It does not disconnect until I actually say something into the mic.
By the way, for carplay, is your phone just plugged into the cubby or are you wireless?
I use a wireless adapter but no issues before when plugged in except sometimes pausing music. Does not disconnect music or Apple Maps if I’m using either or both of them.
Thanks - I sometime use a wireless adapter too. Before going wireless, I ran a cable from my cubby to my tour pack - and put the phone in there.
Can I ask you to try something for me. Connect your phone and run your apple maps. Once you have your maps up, turn the CB on.
With the CB on, key the mic and speak into your headset. Let me know if the maps cutoff. Mine does and they have to reconnect.
I have been talking to Harley about this. Not a lot of folks use their CB with google maps so, they have not heard of this issue before.
It is interesting because, as long as I don't key the cb and talk into the mic, there is not an issue.
Tried it with Apple Maps and worked fine - did not cut off. Got Google maps from the app store and tried it with same result - did not cut off. So no idea what is causing your problem but sure hope you can narrow it down and find a solution.
Thanks so much - we have no idea. Like I said, it works fine but maps disconnect when I speak into the mic.
This is very interesting because it does not cut off when I am using the Harley maps.
Thanks for your help
Dhawk
