confused
Status
Not open for further replies.
Oil Level Cold Check (Copied from Harley Touring Manual)
Perform engine oil level COLD CHECK as follows:
  1. For pre-ride inspection, place vehicle on level ground and rest the vehicle on its jiffy stand. (unless it is a trike..in which case it sits level, no jiffy stand required)
  2. Turn filler plug/dipstick counterclockwise. Remove and wipe off the dipstick. Insert the dipstick back into the oil pan with the plug screwed completely into the fill spout.
  3. Remove the Engine Oil Dipstick and verify the level of the oil. The correct oil level should register between the two marks on the dipstick.
Note: If oil level is at or below the lower arrow, add only enough oil to bring the level to the middle of the two marks on the dipstick.
Maybe this will help too. At the 7 minute mark it mentions pre 07 models.
Status
Bullet Proof
