Help with PIN
Krazeehorse
60+ Posts
Oct 28, 2023
221
1,770
Kenton, OH
I've watched the youtube videos about how to retrieve and reset your pin (2013 Tri Glide). Start with kill switch off. Turn main switch on, toggle kill switch 5 times (ending in "run" position) then hit left turn twice and right turn once. Nothing changes on my odometer display. I replaced the fob battery. Any other ideas?
Thanks, Kevin
My Free is a 2015 so it could be different. On mine you cycle the off/run switch only twice.
Run-off-run-off-run. When you press left turn twice it reads “enter pin”. Then when you press right turn it shows current pin#.
I will try that RK. Thanks. I saw another video that said to press the left turn 3 times. Didn't say specifically what year bike he had. I think it is newer than 2013.
Thanks, Kevin
Not for the 2013. First, make sure you have the fob with you.
Turn the kill switch on (run Position). Now tourn the ignition on - off - on- off and run again. After the third run, press the left turn signal 3 times and the right turn signal 1 time. This will bring up your code.
Now that the code is present, you can use the left trun signal to change it. Example, if the current code says 32123, by pressing the left turn signal, the first number will go to 4. Keep pressing until you get the number you want.
When you want to change the second number, press the right turn signal and it will move to the second number.
Just follow that pattern. When you have the pin you want (write it down) and turn the ignition to the off position. This will save your pin.
Good luck
7447. I tried that and it didn’t work. Maybe it’s me. However this trike was in an accident and had some repairs done to it. It appears mostly cosmetic. New front fender and outer fairing. RK, I’m pretty sure mine does NOT say enter PIN when fob is absent. We will figure it out. Thanks to all so far.
You answered above that it does say, enter pin when the fob is not present.
Make sure you are following the procedure I noted earlier. Have the fob present. Make sure the kill switch is on (try with the kill switch off).
Then, turn the ignition ON. Off. On.. Off and finally on. Left turn signal 3 times and right turn signal two times. You will then see your code.
Do you have the manual for this bike? Just in case your's is different, it is in the back of your book
At this point, it would be interesting to know what happens when you take the fob away from the bike and turn on the switch. Message? Lights on? Will it start? Could the security system have been somehow defeated? I’m running out of ideas but keep us posted.
I don’t think it displays “enter pin” when fob is absent but I will confirm that. I do NOT have a manual. I liked the old days when Harley had pdf’s on their website.
Thanks, Kevin
You will get it right sooner than later, good luck and report back so others can learn
Replaced battery in fob first thing. Trike starts no problem when fob is present. I only have one fob and I'm just trying to do a preemptive CYA.
Just to be clear, when the fob is NOT present and the switch is turned on, is there ANY response at all? Does the security light continue at the same rate?
I will have to look at the security light. I didn't pay that much attention. It wouldn't start though. I'm old school. I wouldn't care at all if the security system was gone and I had to use the key to lock the switch like I did for so many years. Tech is wonderful.....until it fails!
Security light was blinking once every 3 seconds prox. I removed key from the building. I turned the ignition switch on and the security light stayed on solid. I hit the start switch and of course it did not start and the light stayed lit.
I concur with Cycle7447. On pre 2014, it’s ignition switch 3 times, left turn 3 times and right turn once, to display/change pin.
Pre 2014, it won’t read “enter pin”. Without fob present, turn on ignition and press both turn signal switches simultaneously. Then immediately you begin to enter your existing pin#.
You probably already knew that. You didn’t mention whether you have the pin# or you wanted to retrieve it so you that you could change it. I’ll back off now, nothing else to offer. Good luck!
Today when the fob was out of the building I did turn the ignition on and held both turn signals. The display didn't change any.
And to be clear it's the ignition switch with the lock 3 times and the "run/kill" switch on the right handlebar in the run position?
