In the process of ordering a CoolTrikes Grand Touring conversion kit for our 2020 HD Ultra Limited.
Sorting out some of the details on what needs to be done including the ABS and Bank Angle sensor for example and reprograming the BCM to think it's a trike.
One of the questions that has me stumped right now are Harley's TPMS sensors for the rear when you do a conversion kit using aftermarket 5 bolt (car) rims.
After searching on this forum, I know that the Harley TPMS sensors will work on a trike setup once it's been reprogrammed to a trike. I also know that they use a small diameter stem and that I may need to order the FOBO grommets to make them work in the larger tire stem hole.
The issue is the Harley TPMS sensor is a right angle stem. The Harley OEM rim has the stem hole drilled in the centerline of the rim facing the axle, so the right angle stem faces out towards you when airing up the tire.
On an aftermarket car rim, all that I have found have the stem hole drilled in a vertical lip just inside the rim face so that the hole faces out towards you. If you install the right angle Harley TPMS sensor in the hole, it will face up towards the axle which may look goofy.
Aside from that, my bigger concern is the small box that mounts inside the rim to the backside of the stem. Where the hole is drilled in the narrow lip around the rim, is there enough clearance for the small box to mount up against the stem?
Anyone done this and have a pic they could post?
