2008 Goldwing CSC, new to me.
RUMRUNR
100+ Posts
Oct 25, 2016
130
72
Basehor, KS
Delbert
I just bought a 2008 Goldwing with a CSC trike kit, I have had a 2002 with a Champion solid axle kit.
I know nothing about the CSC kit, do they rake the front when they do the conversion?
I have no paperwork about the kit or do I know what year the kit is, any help would be appreciated.
The kit has a vin number on it. Write it down and contact CSC. My bet is they can help.
CSC has an excellent web site. Go to their site, look at technical support section and you will find a video showing you where to locate your VIN. You can also download all kinds of good stuff including brochures, Specs, installation instructions, etc. Good luck..... Jim
Thanks, I was just on their and saw the video, good info on the site like you say.
Thanks, I didn't know what they did at the factory in '08.
Rake kits are done by installer and can be sourced from different companies not just CSC so unless it was done at the factory they won't be able to answer if was done or not.They can tell you who did it and if they are still around and keep good records they should be able to.All that said Any owner up till you bought could have had it done after the original install.
Rake kits normally have a name on them mine has CSC on it my in-laws has Hannigan on it. Look and see if has then it was probably done.
redhog99
