Roadsmith Aux Tank Issues
Oct 4, 2016
118
28
Pontiac, IL
Mike
I have a Roadsmith trike kit on my gl1800 that was installed in 2016. Upon until the last couple times I used the aux it didn’t transfer vert fast. In past it took about 12 minutes to transfer. Today, couple friends and I road 300 miles round trip. When we started back 10 miles from our destination I flipped on the aux. main tank light was on and aux didn’t get above 1/2 tank. It stayed at even level till I got closer to home when it started losing ground. 15 miles from home and aux on the fuel light came on. The aux was on for almost 1 hr and 45 minutes and never gained on tank level. It was still switched on when I pulled into my driveway. Is there a filter or something that needs attention? Would a small blast of low air pressure back through the feeder line clean it out?
Any help appreciated.
I have a Roadsmith trike kit on my gl1800 that was installed in2016. Upon until the last couple times I used the aux it didn’t transfer vert fast. In past it took about 12 minutes to transfer. Today, couple friends and I road 300 miles round trip. When we started back 10 miles from our destination I flipped on the aux. main tank light was on and aux didn’t get above 1/2 tank. It stayed at even level till I got closer to home when it started losing ground. 15 miles from home and aux on the fuel light came on. The aux was on for almost 1 hr and 45 minutes and never gained on tank level. It was still switched on when I pulled into my driveway. Is there a filter or something that needs attention? Would a small blast of low air pressure back through the feeder line clean it out?
Call Road Smith and get advice. If you need a new pump they're $50 online
Sorry to hear of issues with your Roadsmith.......sure does sound like a bad fuel transfer pump.
Nice guys at Roadsmith, I live 2-miles from them here in Minnesota.
No disrespect, but this is one reason I really like the Aux fuel tank setup on the CSC trikes......No pumps, no switches, no solenoids to fail and no dual fill.
All automatic gravity fed and foolproof.
Heard back from road smith and the pump is bad. It’s real easy to change. Said it is down by drive shaft. When I google the number it looks just like the one along frame by where the center stand was. The one I found on google was 12$, theirs is 99$ and will be OE. for the trike. I will be staying. With the original to trike.
