Parasitic Battery Drain
Leaky Waders
40+ Posts
Dec 30, 2022
37
66
Houston, TX
Paul
I have a 2019 GL1800 Tour DCT with a CSC conversion. Using a multimeter, I have isolated a 15A fuse labeled "AUDIO" as the source of a parasitic battery drain. Now that I know the source, generally speaking, how do I hone in on and correct the problem? TIA.
Paul
Paul
Does the radio have a clock ⏰…If so that’s a normal draw…
Thanks for the reply Bob. Yes, the radio has a clock. It's back to the drawing board to determine what is draining a healthy battery overnight when disconnected from the battery tender. Wish me luck.
Ok…Back to more details…How old is the battery? ..
Have you checked the voltage on the battery a few minutes after you take it off of the maintainer or did you do a load test’ anything under 12.7 V it sounds like a bad cell and if so you need to replace that battery…
Yes to both questions. Battery is good. I also checked the ground and found no drop in voltage.
Alternator increases amp meter volt reading on start up.
If I park trike overnight off battery tender the battery is too weak to start it up.
Have you done a full charging system test to confirm it is working properly ?
A bad diode could quickly drain a battery over night
You say if you do not use a battery maintainer over night the battery is too weak to turn the engine over?
If that is true you have a bigger drain on the battery, the battery is shorted and does not hold a full charge, or the charging system is laying down, possibly bleeding diode robbing power
Pull the battery, charge it then have it load tested, do a charging system test and report your findings, just checking voltage @ the battery does not tell the whole story
Ramjet73
