Not really a what I did TO my trike, but a what I did FOR it. Back in 2012 when I put that garage there I bought a rather expensive free floating vinyl mat to protect the plywood floor, mostly from oil from my rather leaky '78 Shovelhead. It was guaranteed to lay flat. Well it did until I actually put something on it then it curled like I had gophers tunneling underneath it. Finally got tired of looking at it and tripping over it and put some 1/2" thick rubber gym flooring on top. Time will tell how this works out I guess.
Looks good, damn leaky Trouble Heads;) My Pan was a bad leaker till I decked the heads and used copper gaskets
Spring Time Set Up
Hello all.
77 & sunny in NE PA.
Changed battery in key fob.
Installed DK Floorboard Extension Kit from DK Customs. Noticed better airflow / lower temps between legs and engine.
Installed Sylvania ZEVO super bright LED taillight bulbs. Noticed brake lights are brighter than stock bulbs. No error codes :).
Installed drink holder to highway bar. Used RAM atv/utv mount, large double socket arm and XL level cup holder.
Went for ride.
"What Did You Do" ... Preview
Ordered the Rider Floorboard Extension Kit this morning from DK Custom. I think this kit will definitely make a difference in comfort as well as heat dispersement. I have seen several vids on installing the kit. None of them were too spiffy :( DK doesn't have an install vid for this and the others show you the start and finish but leave out the actual disassembly and reassembly. The DK Install Instructions are very clear and easy to follow. I have heard many say that removing the factory bolts was quite challenging ... Anyone installed these? Any input on best tools or tricks will be greatly appreciated
Thanks so much
Screen Shot 2023-04-27 at 11.49.34 AM.jpegScreen Shot 2023-04-27 at 11.48.40 AM.jpegScreen Shot 2023-04-27 at 11.49.55 AM.jpeg
Thanks so much
View attachment 112712View attachment 112711View attachment 112710
I put them on my 2017 triglide I put them on by myself, but another set of hands would’ve been helpful, but not necessary. The one thing you find is that the stock bolts have a dry type Loctite that uses a chemical reaction when screwed to tighten so they’re going to be quite tough to unscrew but like I said you can do it. No special tools are needed…
Thanks rhino … looking forward to it. I do have the extra set of hands so hopefully successful installed pics will follow
Washed Kim's Freewheeler today, first of the season and after riding in the rain Friday night.
Some people says Frank's rear fender chaps will damage the paint. I can tell you that is false. These have been on for a couple of years and today was only the second time I removed them. After all kinds of weather the paint and the coat of wax I applied were pristine. A quality product installed properly.
Great pic Mike ... the bike looks great. You should share it on the new "Got Pics" thread. Trying to create a "photo album" I love seeing all the variety. Have been working my way through a "wish list" which does include a set of Franks Fender Chaps (size large like yours) Also thanks for your help with the light visors. A super easy addition that came out great.
Tri-Kit
