2 New to me Stallions
Jun 1, 2022
8
6
Belmont NC US
I am new to the Stallion and wanted one for many years now my Wife and I both have one
We went for a ride yesterday and I noticed a small water leak at the rear , I took it to my Shop and found at the top of the Radiator there was a Radiator Cap but no way to get to it
I looked at pulling the Radiator but ruled that out to cutting a hole in the Trunk and when I peeled the Carpet back I found there was already a cover made pop riveted into the trunk , frilled the pop rivets and there was the radiator cap
8.00 later new cap and no leaks
I do Custom Tuning so I am already doing the software to do a Tune on my Dynojet
I have a lot to learn about the Stallion and I will be doing a lot of searching and asking questions
Tom
Tom
tom should of called don't hesitate next time, if i don't know you didn't lose anything.
Tom
Welcome Tom. I had mine tuned. The timing was way off. Set it to 21 degrees and fooled with the fuel a little. Left the transmission shift points alone. Gas mileage stayed about the same and got more HP and torque from 30-70MPH. Rick
Tom
Tom also if you did not notice, on the left side of the radiator over 1/2 way up if I remember correctly, there is a stub that needs to be capped. If that plug deteriorates it will leak. There is another one under the hood on the right side just in front of the dash area. Same thing.
Ted
Ted
Will check those thanks , It was leaking on the Red one
Tom
Where did you get the cover ?
The PCM has a very strange Strategy , I am working on finding it
Tom
Tom
The top was on it when I purchased it. The guy got it from 8 years ago had it made.
My computer came out of a Ford Van V8 and all settings were still set up like a van. If I remember correctly, timing was set at 10 or 11 degrees. They could of gone higher with the timing, but I wanted it conservative to keep it from being too close to pinging. Rick
