I haven't contacted Motor Trike yet, I have a 2008 Stallion, does anyone know if there are any after market air bags that are a direct replacement or does anyone know the cost of 2 air bags from Motor trike?
Thanks,
Greg
Thanks,
Greg
Greg,
Are you sure it's the air bags? I had a problem with mine leaking down and it turned out to be the compressor. Rick
I had it in at my mechanic for a brake lite issue and while it was there I asked them to look at the air ride while I sat in the trike up in the air so I could operate the air ride. They sprayed everything with soapy water and found that the left air bag has a tiny leak so since it is a 2008 I figure I should replace both air bags together.
Motor Trike Air Suspension Air Bag Replacement (triketalk.com)
Greg here is a posting for replacing the bags on a Motor Trike. They are pretty close to the same bag. Stallion is owned by Motor Trike.
gSorry that's all I know. Being that Motor Trike built Stallion I would guess at least the system is designed the same. I have not changed the bags on my wife's Stallion so I do know. But it should give you a place to start and the changing of the bags should be very similar being that the suspension it similar.
Welcome to our group. take the bag off and see if it has a number or manufacture. there are a lot of companies that make air bags. i replaced a set on my venture and they were bags for air ride suspension cab on an 18 wheeler. good place to start is with MT.
good luck
Dragon
