'21 Tri-Glide Tour-Pac Removal
Feb 18, 2022
3
1
Pocomoke City, MD
I was going to install the Tour-Pac Extender and it looks like the simple instructions that applied to an Ultra don't apply. It looks like I can't reach the two back nuts holding the Tour-Pac to the Support Frame. It looks like I'll need to remove the six nuts, on the inside of the Trunk, that are holding the Support Frame. Disconnect the wiring plugs. Then I can remove the Tour-pak and add the extender between the Tour-Pak & the Support.
Did I miss anything, or is there a surprise that I don't know about? Is there enough playin the wiring harnesses extend the Pac 3"?
Thanks in advance for any advice.
Charles ‘ Welcome to Trike Talk..👍👍
Yes you must remove the six nuts in the trunk and yes there is enough wire play in the wiring for the extension pf the tour pack.
Thanks for the help. I went into the HD online Parts Manual and confirmed what I thought. I was concerned about the wiring harness length though. I was trying to minimize the surprises.
Thanks again!
jkittoe48
