Help Please. Cruise control issue
DOKK
300+ Posts
Gold Member
Dec 17, 2020
363
396
Manchester, TN
Brian
I've searched through everything here without any luck so thought I would post.
I just put a new exhaust on my 2016 Tri Glide and removed the reverse motor while I was at it. I got it back together and everything runs great but the cruise isn't working. It will not come on at all, no light at all. I can't even get it to come on the run the test.
I checked my codes and, under RAD, had B1306, B1342, B1350. 1306 is rear controls shorted high and the other 2 are for my rear speakers. The speakers work fine.
Any idea what may have happened or what I may have messed up, Lol?
Thanks in advance for the help.
I ran the full diagnostic check. The other 2 codes I got were under ECM- P2300 and P2303. I seen to get those whenever I do a flash with my FP3. Those will usually clear and not come back.
Interesting codes, coil driver codes I believe
Back to your cruise not working, it worked before you were working on the exhaust, and the reverse motor?
Yes. It has always worked except when the rear brake switch went bad but then it just wouldn’t set but would turn on (Orange light). I’ve gone through my service manual and electrical manual, I’ve checked wiring and fuses and just can’t find reason unless I’m just missing something.
Did you check to see if you switch is working on the handle bars? I would start there then trace your wires to see if you have a break in the wire or a loose connection. If all the wires and connections check out good then you have a problem a device. I am still new here but, when you trouble shoot something I would start at the beginning ( the switch) and work my way back. Sometime it is best to walk away (because you fixate on one thing and don't look any farther) Check your grounds also ,it could have loosened or just needed to be tightened
Have you ever had problems with your clutch switch? Reason I ask is the cruise switch and clutch switch are contained in the left hand switch pack. The switches are not repairable or replaceable to my knowledge, the complete switch half needs to be replaced.
This could be your problem
Not to my knowledge it’s never been an issue. I did ride it today and also noticed that it is not displaying the air temp on the info screen. I talked to my mechanic and he suggested to put the old tune back on it and see what happens.
EDIT and update: Problem solved. I reflashed the new tune for new head pipes and Slip-ons and everything is back to normal. I guess something went weird when I flashed the new tune.
Good deal:clapping:
