shocks and oil pressure
Dec 12, 2017
32
41
Vienna, GA
Johnny
i was wondering what would be the best shocks to install on a 2012 triglide.the air shocks suck. also what should the oil pressure be on a hot idle.it has 32 lbs at cruising speed. it only has 12000 miles:Shrug:
If i remember correctly.:Shrug:....With my 2011 Tri-Glide .....At highway speed 32 plus or minus seems right......At a hot idle at a red light almost zero ...I had almost 50 thousand miles without any problems when i traded it in....That said Harley gauges aren't known for Accuracy...
Your hot idle oil pressure should be 5-10 PSI
Running down the road warmed up engine 30-35 degrees would be fine
Do not put much faith in H D gauges, when in doubt check your PSI with a master gauge
At least you have a number to look at. On my 2020TG all the information system says is that the oil pressure in OK. WTF is that.
Cheap by the MOCO
It is a good thing these air cooled twins can run and even last on low oil pressures;)
Damn things have run for years on volume @ low pressures
I really dislike idiot light systems on any thing JMO
No one has addressed the shocks I swapped out for Pro Action out of Beaver Falls PA. Hands down the best thing for ride. They are a small business locally-owned and they answer the phone to help with questions. Travel safe Fred
I have Pro action from DK on my trike and Suspension Technologies on my RKC both work great!
On my 13 I was shocked to see my oil pressure drop to zero waiting in heavy traffic. Ridiculous how hot it gets too.
We appreciate Your business, & glad you're enjoying the improved suspension!
Oil pressure should not drop to zero...5-10 is fine. Zero is not.
Yes, heat is a big issue, you may find this video series we did on how to reduce the heat useful-
https://www.youtube.com/playlist?list=PLb3bvZgbH92_3s-2vv63QggFJ3nteFd_C
The above link takes you to the playlist of all the videos, below is the first in the Multi-Part Series-
