Fuel Gauge on CSC with Auxiliary Fuel Tank
It reads the stock GW 6.6 gallon fuel level. The auxiliary tank gravity feeds slowly into the GW tank when the the GW tank drops below a certain level.
My CSC/Goldwing fuel gauge measures the original tank level. From my experience what I see is the needle starts to move after the first 30 to 35 miles and goes down rather rapidly until about the 3/4 level. Then is is real slow to get down to 1/2 tank. And slower after that.
When my warning light comes on I still have over 2 gallons in the tanks. I don't know for sure but I suspect the aux. tanks' top is slightly lower than the OEM tank and the bottom of the aux. tank is relatively even with that of the OEM. Anyway, that's how the fuel gage is reacting..... Jim
My CSC/Goldwing fuel gage measures the original tank level. From my experience what I see is the needle starts to move after the first 30 to 35 miles and goes down rather rapidly until about the 3/4 level. Then is is real slow to get down to 1/2 tank. And slower after that. When my warning light comes on I still have over 2 gallons in the tanks. I don't know for sure but I suspect the aux. tanks' top is slightly lower than the OEM tank and the bottom of the aux. tank is relatively even with that of the OEM. Anyway, that's how the fuel gage is reacting..... Jim
Jim, thank you for the explanation. I have about 30 miles on a full tank and noticed the gauge starting to move. I'll keep watching it now that I know what to look for.
Bill
I agree; this is also what I have experienced.
When my low fuel level light appears on the dashboard, I have about 2.5 to 3 gallons left in the tank.
If I assume 10 gallons of volume in my main tank and auxiliary tank at my average 34 mpg at sea level, then I have a range of about 340 miles for both tanks. I will watch the fuel trip odometer more closely than the fuel gauge, which is reset at the fuel refill. At the 300-mile mark, I know it's time to top off, and I will not second-guess it with a gallon plus in reserve. :D
So my recommendation is to calculate and know your average mpg based on your riding preferences and geographical location, multiply it by the total volume of your stock and auxiliary tanks to get your total average miles per combined tank, and then preset one of your trip odometers to track your mileage per refill.
You can't go wrong.ThumbUp I mentioned geographical location in the above paragraph because at sea level, I average 34 mpg. I will average 37 mpg while in mountainous terrain but will still refill at the 300-mile mark.
When the low fuel light comes on, set your trip meter to zero and you have 90 miles worth of fuel left. I have not tested it to empty, but Will at CSC told me that this is what the range is, actually he says a bit more than 90 miles, but 90 miles is a safe bet.
Randy, thank you for responding and that makes sense. The fuel gauge reads what is in the OEM fuel tank and when it reaches LOW FUEL you still have the auxiliary tank which is full or close to full to provide another safe 90 miles. I'm down to a half tank on my first fill up and will try out what has been posted. I'll report back.
Bill
Bill, My CSC/Goldwing is my first trike but not my first wing. It took me a little bit to become familiar with the difference in how the fuel gage registers. I tracked my mileage and fuel usage in detail for over 4,000 miles. There has been only one time my fuel light came on and then it took only 7.1 gallons to fill. My MPG has been consistently right at 34. I find that my bike will go about 160 miles until the fuel needle is exactly at 1/2. When filling the tank it takes some patience. It can appear full but a real slow drizzle of fuel can add an additional gallon or more. I'll be interested to hear about your experience. Good luck..... Jim
Todd, thank you for the photo it helped me to understand how the system works. This will enable me to make better use of the auxiliary tank and my fuel system in general. Just one thing, could you please show where the Honda takes fuel out of the tank and sends it to the engine? Curious minds want to know!
Regards;
Bill
Regards;
Bill
I'm not Todd ,but i can tell you for sure the fuel is taken from the top of the Honda tank ,the pump is directly under your butt
Yes nywinger you are correct.
The Honda fuel pump sits on the bottom of the honda fuel tank and then pumps the fuel out the top through a fitting at the top of the tank. The vent, pump power wires, sender wires, fuel line out, and fuel line in, all go out through various flanges depending on the year of the motorcycle. These can mostly be seen when you remove the seat.
How many miles to empty does your bike read when you fill it up? Is 178 normal?
Hi All,
My name is Steve and i just joined this group.
I just picked up my 2022 DCT tour from the installer, it showed 29 miles range left to empty. I filled it up and took my time knowing the way the tanks fill up, it took 6.9 gallons, approximately 2 gallons left in both tanks, give or take .1. Maybe it would have taken a little more if I took more time filling it.
As a comparison while on vacation last September I had 30 miles left on my range to empty and it took 4.8 gallons, .7 left in the tank.
I have to log some more miles so I can figure it out and get comfortable with how far I can travel before needing to fill up.
These numbers aren't exact as I may not fill to the exact level every time.
Congrats on your 2022 DCT Encore! Welcome aboard, TrikeTalk, lots of great 411 on the various trikes on the market. Enjoy the ride and be safe, cagers don't see us!
Bullet Proof
