Has anyone had or used any type of exhaust heat wrap tape under the heat shields to reduce the amount of heat thrown of by the exhaust pipes to make riding on warm days especially more bearable.
The place I was looking at had a real detailed price list for all sorts of automotive/motorcycle parts, including just about every kind of pipe you can think of.
I would assume they have the process down to a T but maybe that's why it's so cheap.
The newly gutted head pipe is off a 2011, so you tell me???????????? Man, I hope it fits right. If not........well, I will be sad.........
Rob
Wiz,
So if I start with the Slip-Ons, it's a minor mod I could do over the winter to add some better sound, look more unique, and do so without breaking the bank. Because I am actually content with the performance aspect of the 103 and honestly would like to not treat/ride this one like a racer (gives people more time to stare). Then later, maybe in the spring/early summer, (since the extra, gutted head pipe will finished during the winter), if I get ambitious and decide I want to eliminate the heat issue more, I'll pick up a new intake and tuner, and tear it all apart and put it back together.
But with just the slip-ons, if I decide not to, no harm no foul, right?
If you simply add slip on mufflers and leave your cat pipe on there is no harm, no foul. The ECM will readjust itself within a couple of three tanks of gas back to where you were.
If you install slip on mufflers and replace the head pipe then you are walking a fine line where the ECM may not have enough room for adjusting itself.
If you do any of the above and add a new AC then there is now way for the ECM to make up the difference. You must tune.
Tuning a stock bike will also let your motor run more efficiently.
How you ride it is totally up to the lose nut that holds the handle bars to the seat. :laugh:
