Lehman/Champion IRS trike harley conversion
So I have a Lehman/Champion IRS trike conversion kit on my 2011 Ultra limited that I purchased not long ago I took the seat off and noticed several of the bolts which look to be the sub frame attached it to the harley frame are loose do you have a torque spec for these its either 4 or 6 bolts can't remember exactly thanks
general rule of thumb "tighten the 1st one till it breaks, tighten the rest a little less" works best on blind holes
but seriously this is a great reference
https://www.boltdepot.com/fastener-information/bolts/US-Recommended-Torque.aspx
Rick, your description is vague. You need picture uploading skills too. Did you ever figure out the brake pads yet ?
Seat Mount
1. Install the seat mounting bracket to
the upper trike frame using the following hardware.
Torque hardware to 30 ft-lbs.
• (1) Seat Mount Bracket– S002118
• (8) 3/8” x 1-1/4” Hex Head Bolts– CB2018
• (16) 3/8” Flat Washers– CW2180
• (8) 3/8” Lock Nuts– CN3051
Dhawk
