06 Harley Ultra Classic True duals underneath with side boards, would they fit ?
Aug 25, 2013
8
2
Houston
Hell Forums, just wondering if anybody have a belt driven Lemans trike with floor boards
with true duals going underneath instead of the other type that goes over to the left side ?
I would prefer the change it to put the extra heat at the bottom, my wife's left leg gets too hot.
Rico.......Welcome to Trike-Talk.....:clapping:.....I can't help on the true duals.....But i'm sure someone will chime in soon with the answer....
Rico, Welcome to Trike Talk from West Virginia.:wave4:
The back cylinder head pipe usually sweeps out the left side on a tru-dual exhaust.
You could probably take a set of Long Shots and make a system that looks similar to the 2009 and later.
If you have HOG EFX boards, you may have clearance issues at the rear.
A competent motorcycle shop should be able to help you and it would probably be a good winter project too.
Jim
images
Here is what the left side of a Harley bagger with true duals looks like
Keep in mind these systems are not cheap, good luck in your search
Thank You members your ideas and comments are all very much welcome,
For the rear cylinder we have one like in the last picture, but I was wondering if
the other type of head pipes true duals where the front head pipe go across the
the bottom to the passenger side would work ?
our Trike has the leman’s floor boards installed.
Thank You
Thank You
It could be done by any good exhaust shop ( provided they have a good welder) but, that is not the definition of true duals to a purest;)
I looked at the S & S true duals with individual head pipes,
but they are a bit expensive at the moment, around $450.00
on eBay and I don’t have the funds right now.
