Back to wire problems.
Aug 9, 2019
44
39
Ocala, FL
Charles
Changed handlebars went for test ride. Everything works except cruise control, I get amber light but will not set and turn green. Check engine light is also on. Ran diagnostic test and got following codes: P1510, P2127, P2138, UD142 {may be UO). First 3 are from ECM. UD142 indicates lost communication with RHCM. ? is RHCM right hand control module? If so could problem all be coming from right hand controls? I have just finished checking all connections. I am at a loss as to what to do next. Bike runs fine just no cruise and check engine light on. Any suggestions or ideas will be appreciated.
Thanks again
Thanks again
P2127 and P2138 are codes for throttle sensor , your lost communication code is telling you something is wrong in the wiring in the RS switch half
Thanks for the quick answer, now excuse my ignorance but RS stands for what?
Right Side, did you have to do any soldering on your wires? Does your throttle grip bind? If you have it pushed up too far into the clamp it can bind and throw a couple of codes, the P1510 code will be another code related but not limited to the throttle and engine performance features Good Luck
No solder so will go back over all connections and positions to see what comes up. Thanks much for your help.
