Cruise control problem
Aug 9, 2019
44
39
Ocala, FL
Charles
Just installed new handlebars and all switches and lights working. Went for a few miles ride this morning. Pushed cruise control button and indicator light on speedo came on, when I tried to set speed it would not work. Any ideas will be appreciated.
Also, check your brake lights to be sure they're not constantly on. Brake light switches are a seriously finicky pain in the posterior extremities. If they're on, they'll prevent the cruise control from setting (voice of experience).
That should set a DTC, my 17 Freewheeler for some reason set that code B2223 a couple of weeks ago. Very strange JU JU with this. I did NOT clear the code so I could let the dealer replace the rear switch under my ESP warranty. The code is now not showing up on a diagnostic check. So Where did it go? I dunno and the dealer checked for historic codes and found none. My Freewheeler has healed itself for now, BUT, with the location of the front brake light switch I know it is just a matter of time til it rears its ugly head again.
I have made it a weekly check to see if there are any codes stored. You can have codes without a check engine light on
Kickstand_Korner
