Lost left wheel bearing
Apr 24, 2017
79
67
Sunbury
Bill
Left wheel bearing went out last evening on my wife's renagade. We were within 35 miles of home after almost 200 mile trip. Left it sat went and got trailer to bring home. Glad we didn't ride any further as bearing was completely apart when I disassembled this morning . Will have replacement tomorrow thanks napa. Thankful for the info I have read here on this subject to help in replacing it . Will try and post some pics.
If the other side is just as old I would Be thinking of replacing the other side also ..?
Replace them both.
I hope you were able to get a non-Chinese bearing.
The Chinese bearings are $*** !:mad:
Sunbury ..... PA or OH ?????
Sunbury, Pa. Not sure till I get bearing where it was made. Do you know where there are American ones think I will get 2 extra as we have 2 trikes.
Thanks All
It just hit me ...Rhino2.... what the green meant, I didn't notice and thought it was an over-my-own-head reference !
Thank You each and every member of Trike Talk for this distinction.
I, like Jack, am humbled and I will try not to let it go to my head.
Geeze, I have enough problems already trying to understand why all of the Local and State Government Offices will be closed on my birthday this year !!!
November 3rd MAGAKAG Day
This is a GREAT bunch of folks here, We can make a difference working together:clapping:You have a wealth of knowledge;)
Thank You for all you do Jim! You are truly loved and appreciated by all here!
Parking brake question. Appears parking caliper can just be adjusted by loosen locknut adjusting stud in and retightening so that theres no drag. Does this sound correct. It appears disc pads on e brake are thick enough. Thanks Bill
Yes that should work. After doing this verify the brake pedal to be sure the hydraulics are applying and releasing;)
TBM Parking Brake
Thanks for the info.
Bill,
That particular parking brake is like an old Go-Kart mechanical caliper.
As the pads wear you can adjust by relocating the lever using the stud on the back but they are notorious for making noise and locking up and not releasing.
Lubricate the rails of the caliper and then make the final adjustment at the cable connection by the hand brake lever.
This guy is kinda screwy but you get the idea of what you are trying to do anyhow.
Thanks. Found right side shoe was stuck an froze in caliper. Got it apart finally cleaned it up and reassembled. Adjusted and all seems well. Will give it a good road test tomorrow before turning back over to wife. Are those pads available to purchase somewhere?
Go here: mjtrikes.com
S001304 puck
GB1144 pads
:D
Geezer72
