Radio 1500 Honda Goldwing
Apr 28, 2018
21
25
perryville
Nicholas
My 1999 Honda Goldwing radio vol is so low can hardly hear it turn off the mute button and still low is there a fuse that may need to be replaced any advice on what to do
Does it still say mute on the display?If so it could be a problem with the ground wire to the handlebar control.Also I believe there is a fuse to the amp.
I had that before but dont remember why it happened. I believe I removed both the main radio fuse and the backup fuse that is tucked into the relay side. I left them both out for a couple minutes and then put the fuses back in. The radio volume was back to normal after that.
Dug this up off the net concerning this problem. Seem like it resolved the problem:
Behind the left side cover is the fuse box, to the right of the fuse box another box with relays in it. In that box there are 2, 5 amp fuses. Check them. It's been a long time since I had a 1500 wing but IF I remember right that is the cause of your problem.
Hope it helps
where to find fuses and relays
https://www.youtube.com/watch?v=Ji0Zkb18cRg
Bullet Proof
