Reverse
Hi Pitbullpo, the GW reverse is relatively simple. You need to be in "N" with the motor running, then push in the "R" button on the right handlegrip, when you see the "R" lighted on the dash it is ready to travel in reverse. Simply push in the "starter" button and you are moving. Reverse the process to get back to forward. Also, the heal/toe is much easier on the leg muscles. I absolutely love mine and would highly recommend it! If you are getting the H/T with the TRike it is simple. Push the toe to downshift and the heal to upshift - very simple you will see (you never have to lift the shifter with your toe). Good luck with the new Trike, you have a good one.
Milia
