brake fluid check
whats the best and easy way to check brake fluid on my stallion my brake lite os on in my dash
The fluid reservoir is located on the master cylinder under the trike a little more than half way back. It is inside the frame work more on the left side. You will need to remove your seat and have a long neck funnel if you need to fill it. The reservoir is semi see through so just by shining a flashlight on it you can see the level. It is only a very little visible from above so you have to get under the trike to see it. When you have the seat out it is just to the left of the back rest post receiver but under the trike. Hope that helps you.
thank you for the info
edumou
