My gearshift will not engage
Aug 24, 2009
17
4
PA
Victor
2008 STALLION
Something broke and just get loose ?
It stated with that i have to shift to second gear and then to d to engage
but now it will not engage to any of the gears
please help
thank you
I'm betting that there is a bushing of some sort both or at least one end of the shift cable that is worn. My wife is having the same issue with hers but I will not be looking at the issue until later this week.
GEARS
I STARTED TO TAKING EVERYTHING APART HOPING TO FIND WHERE THAT WIRE LEADS TO :confused:
Victor i found my wife's problem. The shifter end of the shift cable the bushing was completely gone. The cable end loop stayed over the post but there was about a 1/2 inch of slop so it did not hit the proper gears when moved. The cable could of easily come off making for no ability to change gears at all.
I made my own bushing out of 1/4 in rubber hose 3/8 in long. Put it on the post on the shifter and then slid the cable loop over the bushing. Because the factory bushing has some kind of locking mechanism to hold the cable on, my repair I had to devise a way to keep the cable from sliding off. I took 2 plastic wire ties and made o loop around the cable securing it to the shifter post. Works great.
Look under the hood at the shifter and see if the shifter cable has not come off causing your problem. If it is on see if you can push it off the post and if there is slop in the post to the cable end. You might have the same problem. There is also a similar connection at the transmission end but looking at pictures I think it is a little different and might not be subject to the same wear. Keep us advised.
GEARS
i check the wire by the shift gear and its connected
i thinking that is by the gear box ? any idea how to get to gear box
i look under the bike and no luck finding the box or wire :confused:
do you have any photo of what you did ?
Gorilla
thank you for help
Gorilla
thank you for help
Victor just so we have our terms correct, when you say wire are you referring to the shift cable? The shift cable is a good 1/4 thick end with a loop and the cable itself runs in a sleeve. Sorry no photos
The cable attaches to a lever that comes out of the side of the transmission. This lever is located on the left side of the transmission. It is right in by the master cylinder. The cable is mount similar to what you see at the shift lever but the connector appears to be more rugged.
Gears
Thanks Gorilla
With your guidance I was able to track the problem down it was the cable came loose by the gear I put it back and use Loctite and hopefully it won’t happen again
Gear
Sorry I try to put some pictures on of the problem but I had no luck
Sorry disabled veterans heavy medication so I feel better I’ll try again
MelT
