Wanted to install my new Mustang seat, but it appears it does not fit with the way I have my tank lifted... I am hoping adjusting the tank works to install my seat!! Any suggestions?
I have a 1.5" deluxe tank lift & I know you have some leeway in moving the tank forward/back.
I don't have a Mustang, I have a HD Sundowner Tallboy, but they install the same way.
Let us know what you find.
My seat definitely needs to move forward some... It currently rests past where I need to secure it! Hopefully I can mess around with it this weekend... work gets in the way of having fun. Grrrr
Work did that to me also, so I quit.:) I have to raise the back end of my seat up at a large angle & bring it in to catch the tongue it hooks on, then lower the back end in place.
I have the seat all fixed!! I will need to get the backrest from Mustang Seats though. My grasshopper backrest will not work, the bar is too wide! Guess I will be selling that backrest... only had it a few months and do not need to let it sit in the garage gathering dust. I also had my reduced reach brake/clutch installed. Can't start my bike in first gear anymore, but that is not a big deal to me. Still need to install my flip blade highway pegs... they came in the mail today. :D
Saturday the bike goes in for the 1k check up. After that, I should be able to log some miles! :clapping:
If you can't start your trike in gear, after applying the brake, you have a problem. When the new clutch/ brake levers got installed, the switches either got broke or misaligned.
[SUB]Rick from softbrake has a video on youtube about what to do if your bike does not start in gear after changing the lever. It is just a matter of shaving off a little bit of the ramp, as he calls it. Seems like a rather easy fix. It starts in neutral without issue and shifting doesn't appear to be a problem either! Thank you for the heads up though. :wave4:[/SUB]
I cleaned my FW up, checked all fluids, lights & did a diagnostic check & all was good.
I also checked the battery voltage & got 12.97 VDC. I plugged in the battery tender as I may not ride till next week.:cool:
Can't go wrong plugging in the battery tender. Mine stays hooked up whenever I am not on the Trike.
I hook it up when I know I'm not riding for a few days. These new batteries just hold a charge better than older versions. I have had it off charge for 4 days, plug it in & in 30 minutes it switches to maintenance mode.
You are doing a BIG favor to your charging system using a tender:clapping:
  • Like
Reactions: MDO
View attachment 72641ordered a fl-vied, now planning for a EBS. Will running with a stock A/C require any drilling, will tubes fit behind the A/C.
Look here
I ran 1 like this on my 15 Freewheeler Required 1 hole for exit of hose
  • Like
Reactions: MDO
I got a nice, leisurely 50 mile ride in. The rain moved out & the weather got very nice here & I can't ride tomorrow, so I took advantage of it. My baby is purring like a kitty. There were lots of bikers out.:cool:
Thanks for the info, I will follow your example
Jack has great info. That is pretty much how I did my M8, but I added a K&N air filter in the stock box.
It was a definite performance boost, but it was before I knew about DK Customs & if I had it to do over, I would use one of their air filter systems. I got their 1.5" deluxe tank lift & need to order their air wing deflectors.
I just ordered from DK Custom Products, the new Thundervolt 50 Taylor spark plug wires they now carry & the cooling wing deflectors.
The spark plug wires are the best price anywhere. I'm very excited to install everything, but I now need to get some new plugs. I'm not going to make pulling the tank a habit.:cool:
;) The cooling wings are a Big plus, I like mine
If I did not have an in store credit I probably would not have got H D plugs ( made in India) I would have got NGK
  • Like
Reactions: MDO
I'm going to try the NGK plugs. I will clean up the OEM plugs & keep them for a backup.
They are most likely fine...I will find out in a few days. My DK Customs order shipped priority mail this afternoon. Great customer service. :Dorag:
Installed the fl-vied, set it just past 50%. It seems to run perfect. I have a 2016 with v&h slipons.
Is there a hi flo k&n filter for the oem 2016 a/c?
I was bad today...
A beautiful Saturday...perfect riding weather and a forecast of
rain for the next SIX days...I threw caution to the winds and rode
in short sleeves and jeans , and the smallest helmet I own.
I know , I know , all the gear all the time but staying on local roads
and never past 4th gear , it was the BEST ride I've had in a long time.
It won't happen again...I promise :laugh:
Dante
It was raining this morning, but I went & picked up my 4 pack of new NGK plugs from Advanced Auto Parts. I order online & pick up in store to take advantage of the 25% discount & the plugs were $11. My new plug wires from DK customs should be here Monday, along with my air wing deflectors.:Dorag:
I received my order from DK Custom Products, air wings & spark plug wires. Ordered delivering in 3 days, that's great service.
I now need to find the time & good weather to install everything.
Just so everyone knows, I tried installing NGK CR9E spark plugs in my M8 2017 Freewheeler & the wire end of that plug is not correct. It does not have the small piece that you screw onto the threads.
I will post more when I finish sorting my mess out. I know numerous times in the past I bought spark plugs & that little metal piece to screw on the threads was in the box, but not this time.
Some days peanuts, some days shells:laugh:.
I went out to the garage and looked at mine then went back in the house and sat in the air conditioning. Heat index today is 105. Like riding in a sauna. Rode about 60 miles to lunch yesterday and was soaking wet from sweat when I got home about 1:30. Have to stick with breakfast rides until the weather cools off. Garage isn't air conditioned so too hot to even work on it after lunch.
Sunman
Well
Sunman
I guess that's the price you pay to live in the most sane state in these
United States
God Bless Texas!
Dante :clapping:
3WHEELR
