Horn
rocket1lf
450+ Posts
Dec 7, 2013
544
220
Hot, Arizona
Rick
I finally decided to replace the horn. Wow what a difference. went with one of these off ebay.
12V 136DB Dual Tone Compact Air Horn Loud Electric Trumpet Compressor Car Motor. It was only $17.00. Rick
How hard was it to get underneath to the original horn for the wiring. I was told you have to pull off the plastic rock guard on the bottom to get to it. Tomg
Yes Tom, that is the hardest part. It's not that difficult. I ran the Stallion up on a ramp and worked from the bottom and top to get the screws out. Then I just used the same horn mount and extended the wire about 6 inches to get it to fit. Rick
Good info! I started to change my horn a few years ago but never did. Just never was a high priority and alway went to the bottom of the list for things to do. You got a good price for yours. Tomg
That was one of the first things I did when I first purchased my Stallion many years ago. I had to remove the shield in front of the engine to access it as I definitely wanted to toss that OEM fog horn that came on it. I replaced it with a Stebel Nautilus air horn. It is compact and will fit in the same location. It is forevermore loud. Here is a link to one like I have.
https://www.ebay.com/itm/Stebel-Nau...193801?hash=item5d8ae49189:g:2okAAOSwOttcz~ch
That looks like the one I have, only in a different color. Rick
Trike#1
