Installed my Love Jugs
Z06tacoma
90+ Posts
Gold Member
Apr 5, 2019
77
124
Crawfordville, FL
Mike
I didn't want to derail the other thread so I started a new one. Put on my mighty mites today.
The old vibration dampner was a pain but got it off.
Install went easy but was having a hard time with finding the right plug for the harness. My manual said the accessory plug was on left side. I found it, a 4 pin, along with a 6 pin. Neither of them fit the Harley adapter.
Then after some more research, I found out the correct plug to use was on the right side.
Now if the rain will stop, I can test them out.
By the way, what are the left side plugs for? 2018 tri glide.
Love Jugs up and working!
Per all you smart guys....purchased Mighty Mites and the 8 Pin Adaptor for my 2015. Got them much faster than it took me to get around to putting them on. All the small issues as expected ~ Old vibration dampener was a bit of a bitch to get off....and routing the wires was goofy but got them out of the way and secure. Having forgotten that when I bought the trike they put in the accessory switch to run the small "Fog" lower lights. So...I just cut and spliced into the leads hanging out under the seat that said Accy2. Found the wire that was switched and bang! Damned if it didn't work...I hate Electrical. So...small ride, all seems as it should. Rather than send the adapter back to Papa Zook....pass the word I have one and would appreciate if they they could just pay me and I too will ship free. Still in the little baggie un-used. Thanks for all the input and stuff - jc
Believe me you will never want to turn them off I never do. Your motor will last a great deal longer and stronger, I'm sure of that. ride safe Fred
Thanks Fearless...I do believe I will just leave them in the on position....but I do like that with them being connected to a switched circuit that they can't be turned on accidently or Maliciously.....We have a Vacation coming up soon, and very sure we will be stuck in at least a few traffic lines....hope they work as promised!
All I know is that my 2015 is in love with the Amsoil 140 wt. Severe Gear....If I am traveling and it gets a bit cold over night, I make sure I don't park in gear. That tranny takes a bit of warming up! lol
Yep! When it's down in the 30's and I'm not riding very far, I won't turn them on. If it's in the 40's or above, they're on.
I've got somewhere around 200,000 miles, riding all over North America with bikes & Trikes that have fans. There is a switch at the fans that turns them on/off...regardless of a key.
Knock on wood, I've never had anyone switch them on.
OTH, I have left them on twice, overnight, and come out to a dead battery both times. Once on the Tri Glide while on a trip, and once on the Softail, parked at my house.
Both times I was able to get them started with my portable jumper. But I'm sure I reduced the lifespan of those batteries.
The reason I like to be able to leave them on is that the engine can be quite hot when it is shut off, and that heat travels up and out the top of the engine....leaving the fans on for 10-15 minutes when it is really hot is a help. I imagine you could do the same thing with your accessory switch.
I think you will be well pleased with them...you have a Twin Cam, and they are just as, or a bit more, effective on the TC as the M8. Here are the results of some testing I did just last week.
wzejda
