Fishtails
Dec 22, 2018
76
39
Fredricktown, MO
Ed
Been searching for a set of slipons for the 2019 trike, in the fishtail style with no luck. The total length needs to be 30''.. Anyone have a lead? Also what size is the exh-pipe?
Thanks.....
I would assume that the exhaust did not change from 2017, 2018, to 2019. I don't think I have ever seen what I think you are describing sticking out from behind a TG. Wouldn't they be subject to dragging on everything?
Thanks.....
I run a set on my 19. Took them off my 15 FLHTK when I traded it in.
This is what I am running now.
They certainly provide a unique look to the tri glide. Are you at stock height or have a lift kit installed? In much of the rural riding I do, even with the lift kit, I'd easily destroy the bottom fins on those tails. Just too many uneven turns into and off of roadways, parking lots and driveways.
I think it's great we have so many choices to suit our personal preferences.ThumbUp
I love the way they look. Absolutely no problem whenever I'm riding. The bottom of the Fish Tales are 8 in off the ground. I do have to put a couple of two by Eights on the ground at the bottom of the ramp when I back at off my trailer. Without the two by eights they do dig into the ground. Everything else is completely stock no lift kit or anything. Stock motor also
Thanks a bunch guy's,
I have A bumper, they only need to be 2'' longer than the stock muffler @ 28 1/2''..... So around 30-31''.
Trying to keep them as close to the bumper as possible.
The ones I am running are 34 in Long. The stock pipes are 29 inches long but they don't stick out past the body of the trunk. These stick out 7in past the body of the trunk but not past the overhang of the tour pack. They are baffled. They look good they sound good and it runs great. No flash of the ECU was needed
I got them from American classic motorcycles in Zieglerville Pennsylvania.
Similar threads
TrikeBoss
