Jack Klarich
Gold Member
This is a must to replace spark plug wires, not so much if you are just doing spark plugs
1 I pulled the main fuse
2 remove seat
3 disconnect fuel line ( push up on the collar pull down on the line)
4 On the left front bottom of the tank lightly pull on wire that runs to fuel gauge and un plug it ( I believe the manual says to draw the fuel gauge out of the tunnel to unplug it , IMO too much work and NOT necessary )
5 remove rear bolts on tank
6 unplug wire loom running near top of battery up and under gas tank ( there is NO need to remove the console) unless you want to do extra work that is not needed
7 disconnect the fuel vent hose
8 remove the front 2 bolts holding tank to frame and lift the tank off
Reverse the steps to reinstall, take care when setting the tank down on the frame
2 remove seat
