V Trike Cruiser Clutch or clutch adjustment?
Feb 25, 2019
33
12
South Elgin, IL USA
Got the trike running, as noted before. Idles fine in gear with clutch held down. The very slightest release, feather, engages trans. I'm going to raise rear so I can get a look see. Thoughts?
MR TRIKE
Hello- You need to have more free play on clutch cable. To do that, there is a wingnut at the transaxle end of the cable. Turn the wingnut counter-clockwise a couple turns until you have about 1/8" freeplay when push forward on spring loaded lever that clutch cable goes thru. That is VW"s recommended clearance. That will give you more free play at clutch pedal. You can adjust from there. "KEEP-ON-TRIKEN" Dick
