Oil Dip Stick 2019
Nov 19, 2012
255
91
Bradenton, FL.
Anyone else find it hard to unscrew the dipstick on a 2019 after a ride or the day after a ride. I can screw it in and out after that with no problems just after a ride. Thanks
While I don't have a 2019 that's pretty much normal in my experience on all my Harleys. Sometimes it takes both hands to get that bugger starting to turn. Al least it won't unscrew itself and come out, lol.
Normal......Both my 11 T/G and my 17 T/G were the same way....
Thank you all, I thought it was just mine.
Nah. They all do that.
My 19 is pretty tough, when I first tried it I thought about a rag and pliers lol.
By chance, do they make the one with the temp gauge to replace the stock one?
Ride Safe..................
Yes they do have them with a temp gauge....
I purchased a knurled transmission dipstick from JP cycles sometime ago Check their site out I really like mine easy to check just like motor oil. travel safe Fred
62700194
Oil Level and Temperature Dipstick with Lighted LCD Readout
New and improved “capacitive” level sensing technology provides the highest degree of accuracy and durability. This dipstick allows you to check your oil level and oil temperature with the push of a button. No more grabbing a rag to pull your hot dipstick. No more oil drips on your pipes and on the garage floor. Gloss black finish Add function and style by replacing your stock dipstick with this hard working version Simply push the button and this dipstick lights up with a brilliant backlight Oil level is indicated by a four-segment readout – it even reminds you to check your oil when it is hot Waterproof LCD (liquid crystal display) readout operates on long-lasting replaceable lithium coin-type battery (P/N 91800066) Display features a low battery indicator and press-and-hold feature to toggle between Fahrenheit and Celsius
Fitment: Fits 17-later Touring models. Does not fit Trike models.
Kickstand_Korner
