Chrome parking brake pedal
Sep 23, 2018
233
140
Pa
Joe
Anyone seen or heard of such a thing? Looking at left side of trike and "I" thought it would look good.
It would look good. The only thing I have found is a brake pedal pad part number 42476-95. I have the chrome and rubber parts on the trike. I believe they have the other styles also in the same size. I would also like to know if there is a chrome lever for the parking brake.
I saw where one guy had used a foot brake pad and put it on his emergency brake. Looked good and I was thinking of doing it. I am not sure if there is the same hole in the flat metal part of the emergency brake like there is on the foot brake or if you have to do adapt the part.
My Tri-glide is a 2016. I am not sure it will work for newer models but I don't see why it wouldn't. Fits like it was made for it. No problems other then getting that ugly piece of rubber off. It just bothered me. Glad it is gone.
mdo
I posted it both Freewheeler and tri glide. Did I break protocol?
Quiet rider
Nice job! You've dumped a ton into making tg shine. I would love to see it on a sunny day. Wheels look fantastic, so do all steel braided.
Brake pedal
Does the brake pad mount with a bolt without fabrication
Oil cooler
With the winter months here I want to put an insert into my oil cooler cover, (freewheeler) don't want to block air flow but protect cooler. Pa uses tar and stone chips as a roadway fix. Another fw rider noticed oil leakage from cooler and several fins were dented.
jkittoe48
