Torque value on Honda GW Champion Independent rear hub
I think most hubs require 250 lb/ft of torque. HOWEVER, I would call Champion to verify, OR, if you know brand of hub then call local auto supply and they or internet can probably give you accurate answer.
You are right Mike. I had to remove a Roadsmith hub a while back and was floored that it was so high. I would give Champion a call to confirm.
Bullet Proof
