maybe goofed up
hit reverse button can here it click but doesn't move any ideas ?
Check the breaker behind the right side panel, under the seat...
If its ok , Then most likely the reverse motor is bad...Been there with my 2011 Tri-Glide.
What year is your trike, And do you have a warranty ...:Shrug:
Same happened to me. I opened and reset the reverse breaker 3 times and it worked and no issues since. I am not sure what caused it, but it continues to work. Jim
One key thing to remember when using the reverse on your trike. Do not hit the brake while the reverse motor is engaged. Hitting the brake puts a lot of extra strain on the motor. It will in most cases it will trip the breaker but a lot of cases it will fry the finals in the starter motor. Just FYI.......
8~\o
8~\o+
And it's a two part reset.....best shown in your owners manual. One on the face and one around the right side?
8~\o+
Thank you, did not realize that.
8~\o+
Thanks for that info.....good to know stuff for us noob trike riders....
Lon
El Cabron
