Speed Bleeders for 2011 Tri Glide REAR Calipers
Does anyone know for sure what the part # is for the rear calipers on a 2011 Tri Glide?
In reading other forums I get 2 different #'s
Thank you for any and all replies!!
Have you checked on websites that show parts breakdowns, like Ronnies.
Also, it's much easier to get an inline check valves like Motion Pro sells, and put it in a piece of tubing and use it with the stock bleeder screws. It works well. Don't quote me but I believe they are around $12 & you only need 1.
If your set on bleeders at each caliber, check here.
http://www.speedbleeder.com/
No listing on Speed Bleeder site. Way old.......Needs updated.
I'm pretty sure they are 8125L , but I want to be sure.
Also....I want to flush out the rear system......Need 2 then.
You can suck most of all the old fluid out of the master with a syringe, top it off with fresh fluid
Crack each rear bleeder loose, let it gravity bleed til fresh fluid runs out
Tighten the bleeder
Fill the master back up, pump the brakes short slow medium strokes, do 1 bleeder at a time 1 more time
Refill good to go
I just did my Freewheeler, ft, rear bake and clutch fluid Good to go
3/8 x 24 is most common size bleeder
You can verify this by removing the bleeder and winding a 3/8 x24 nut on the threads
  • Like
Reactions: MDO
Right rear............83426-09B..
Left rear..............83427-09B..Hope that helps....:Shrug:
