Boom box reset
Nov 22, 2016
245
133
Groesbeck, TX
James
I bought a used 2016 with less than 10k on it and was wondering is it worth it to have the radio/gps set back to factory settings or wiped clear of the stuff that's in there
If you want reset the BoomBox, here are the directions.
[FONT=&quot]To enter the service menu:
1) Turn ignition off and wait 15 seconds
2) Press and hold power/mute button. Turn ignition to accessory.
3) Continue to press power button for 2 seconds after warning screen is displayed.
4) Release power/mute button and accept warning
The service menu will display the following options:
1) DTCS
2) Audio a) EG (serves no purpose) b) Speaker test(s)
3) Display (test the LCD display brightness and color consistency)
4) Key input (test the faceplate hard keys, handlebar switches, and passenger controls)
4) Component menus (XM and Satellite Digital Audio Radio Service)
a) Module version-displays the XM versions
b) Subscription info
c) Signal status
d) XM antenna state (unsupported, detected, not detected, short, and unknown)
e) Tone generation (allows for generating left or right audio tone generated by the xm
module)
f) Navigation setting (no diagnostic value)
g) GPS status (displays a graphical representation of GPS satellite position signal strength)
H) Tuner-displays the current frequency, signal strength, RDS/RBDS info for each tuner.
If the signal is unavailable or out of range, the display may show dashes instead of a value.
I) Compass indicates current direction
5) Version information (sub menus show navigation and database versions but offer no diagnostic help.
6) Reset
a) Precalibration reset-restores factory settings-recommended when there are no problems or
DTCS..
b) Post calibration save-Archives customer settings after post calibration reset
c) Post calibration reset-Resets radio default settings and restores customer data stored in post calibration save
d) Privacy reset-clears private data (phone pairing, phone #'s, presets, navi history)
7) Touchscreen Calibration 6.5 only
Calibrate the touchscreen by pressing the center of the displayed target. The target moves
to a new location on the screen after each press for a total of 3 presses. Press accept
for the calibration to update.[/FONT]
Hope this helps. it worked fine on my 2016 Tri
Nuc
do you do this touch screen thing in the nav mode or radio mode? also what key position, thanks
Steps 1 thru 5 state how to get into the menus. Just follow the steps. Once you are in the menu, you just have to scroll down and reset using the reset menu. Most likely you will use C under reset, since you want to set back to factory standards.
Nuc
Steps 1-5 followed, but Radio just stays off while holding the start button down?
Nuc
I have tried to follow steps 1-5 but the radio never turns on to display the <accept> button. Just curious if it may be a serious defect or if something to do with the fact I updated the Software Version from the stock 1.18.0 to 1.22.0.1 on March 14, 2020. Perhaps there is a new way with that version to get to the maintenance menu to initiate the factor reset? There are two reasons I want to attempt the reset. 1. the bluetooth just sits at initializing and 2. I messed up the navigation by selecting All by mistake and it will not allow me to now delete each entry as it just will hang when I try.
ledgin
