codes
Cannot find that code for a Harley
An automotive code with that number would be a stepper motor IE a throttle positioner maybe
Rescan it again and be sure of the number
Write it down and clear the code
See if it comes back
I have reset it 3 times I don't have an engine light on but I just remove the reverse motor maybe that has something to do with it I have a mechanical reverse so I decided to take the motor out today since it doesn't work
That could do it
If the ECM sees an electrical connection NOT making a full circuit it could do strange things
Specially if this is a Can Bus System
https://www.triketalk.com/forum/threads/43035-Harley-trouble-codes
You can read more here
And Here
https://www.kriss.com/can-bus-info.htm
Reality2025
