Having to loosen belt since installed DK shock angle plates to tight
I figure now have to loosen pinch bolts and adjust the tension bolts. ASSUMED that dealership set that when bike put together, guess not. Was a little tight when got Freewheeler, guess now that my next project! Never evening, but learn more about Freewheeler since don't have a service manual! 😜😜😜😜😜😜😜😜
A proper belt deflection tool should be used .... and yes ... they feel damn tight when properly adjusted!!!
Bob :Dorag:
DK Lift Kit
Thought belt to tight, that wasn’t the problem exhaust on right side hitting exhaust pipe. Had to cut off 1/2 inch of the part where CAT is and 1/2 off the offset pipe. Now doesn’t hit swing arm. Does improve ride now.
The M8 motors requires a different lift kit bracket design than the TC103's due to changes in the exhaust.
Could it be that you received/used the wrong bracket for your application?
Bob :Dorag:
DK lift kit
Could it be that you received/used the wrong bracket for your application?e
Bob :Dorag:
Called DK Today, told them my issue. We talked about the extension off CAT, possibly when extension welded to the bell, was welded off. What I did corrected the problem.
Ron A
