Where is the best place to buy an HFSM replacement module for a 2010 tri Glide Ultra?
Also, what is a good general purpose diagnostic instrument?
Thanks jc. I was looking to replace the HFSM rather than disable it. I have a copy of the shop manual. PS Did you know that if you pull the main fuse or disconnect the battery, you have to go through the full PIN setting process to get your Fob to work.
When i changed the battery on my 11 T/G The FOB worked without resetting the PIN#
And on my 17 T/G I disconnected the battery to put in a pig tail for my heated jacket , Also Without a reset needed ...:Shrug:
