Just had the pump go bad - Not a problem as the dealer had it in and out in 24 hrs. and warranty issue, so Zero cost. But curious is this has been an issue for anyone else.....Mine's a 2015....jc
Good to hear that got you taken care of quickly.
At just shy of 50K miles on my '14, I've not had any issues with mine.
We did run across a guy stuck on the side of the road in Utah somewhere that had his pump take a dump. But it was not a factory issue...he had run over a big rock and it had cracked the pump housing.
We kept him company for a bit. His friend was on the way back from the dealership with a replacement pump when we headed back on our way.
I'm curious ~ as the Wet Heads" are strictly a "get past EPA" regs....that you could drive without any real issue as we have been driving the 103's for 7 years now. Same engine minus the wet heads that only bring the temp down low single digit numbers. I wasn't sure what my problem was - but if i did, not sure I would have stopped my ride. Thoughts?
How do you know when the pump quits?
IN my case I didn't ~ Almost at the same time the Engine and Temp lights came on. When I took it in they suspected the sending unit - Not the case. So I had no idea, and on first glance, neither did the dealer.
jc
Last July my pump gave out up in Ottawa for the National HOG rally. Neither dealer had one(sold the last one the day before). Both said it was a Harley so I shouldn't have a problem if I stay away from congestion. Not easy to do in a large city, so most of the time I took a cab or bus. Didn't have a problem on the way home other then my clutch. I finally found a dealer that had a pump in Niagara Falls. They switched it out, took my $50 co pay and sent me home.
I would have no problem riding without the pump if I was on a highway with little to no traffic. .....after all it is an air cooled Harley for the most part.
Well...thanks for the input from all...I like the "good for 200 miles" remark. Like 200 miles at 70 would be the same as 200 miles at 45 mph. So....after reading and thinking it over, with all the money invested in the bike, and somewhat differing ideas from people with a better knowledge than I....if it happens again....Stop and tow it in.....why take the chance....JMO
jc
