Harley Trike Muffler Swap
Jack Klarich
Gold Member
Oct 11, 2016
18,131
15,215
Jacksonville, FL
Jack
I think I have found an easier way of changing the mufflers on Harley Trikes, once you get the old ones off
I put 5/ 16th studs in the rear holes of the mufflers
I found this easier to align them and easier to turn a wrench on than a bolt
The front bolt is not bad to start
With the stud in you can massage a flat washer a lock washer and start the nut with your finger tips, then tighten it up
I hope this helps
Sounds like a good idea. I am going to try it next time. Getting the rear bolt started and tightened is a pain in the rear (no pun intended).
Sunman
I tried flipping the rubbers and mount brackets also, this makes starting the rear bolt easier, however it puts more strain on the mufflers IMO the height changes albeit just a bit, but that is all it takes to put a bind on the exhaust and cause a ringing harmonic
The stud IMO is easier 4 me, it may not be 4 everyone
I looked at this from a lifetime of turning wrenches
I have just about every 1/2 wrench u can imagine
That rear bolt aint 2 bad if U have a distributor wrench:p
Good tip,speaking of old tools i happened to see the other day my flexible allen wrench for setting the points on a chevy dist.
I just used mine the other day to align the headlight on my trike. Been setting in the drawer for years
