Floorboard
Apr 4, 2012
74
7
Woodland NC
Bill
Is there any way i can raise my left floor board to 1 ½’’ or 2’’ I'm amputee my leg hangs drown to far makes my stump goes numb. I have a 2012 Harley Davidson trike.
I don't know how handy you are but you could probably get another floor board and with spacers adjust the hight and then mount it directly onto the existing floor board 📞
A friend of mine; who is above knee amputee. Used HDPE Marine Board because of its water, oil and chemical resistant. He just took the pad off and traced, cut and screwed it down. Also he order it in black. Raised his foot plate 1 1/2 inches.
Ride Safe
Nuc
[h=1][/h]
i'm a above the knee left leg amp. too. i've thought about this myself and it looks like you could take another floorboard and pull the rubber off and bolt the new one on top of the old one. kinda like a footboard sandwich. this would raise it quite a bit. if it's still not enough you could use some spacers or washers to raise it even more. gonna take drilling some holes in the right spots. then the stock rubber pad goes right back on. the only thing that would limit the height would be the shifter, but i have a hand shifter on mine, so no problem for me. good luck !
^....Good suggestions on constructing a floorboard extension.
Here's a shot of a hand clutch/shifter mod that might be of interest, if your existing shifter cannot be used. (Disregard if you have a hydraulic clutch m/c)...
Nice set up
I bet a hydraulic set up could work on that HMMMMMM
Joe Henry
