Avon Trike Tire
installed in January and I now have 8,900 miles on the Avon front tire. It shows very little wear and I'm really pleased with the performance.
2012 TriGlide
Good to know. New Avon going on mine tomorrow. Got 13k on the stock Dunny, might go a little more, but going out of state in a couple weeks, so replacing it now.
I also have Avon tires on my Roadsmith, I'm new too triking so this is my first trike, and have put on maybe (guesstamate here) 8,000 miles and so far front tire still looking good..........
I will replace with another Avon tire when needed!
Ronnie
Got about 150 miles on the new Avon front. Dealer put it at 36# and it seems to wander just a bit at speed. Today I bumped it to 38# and it still seems to wander a bit. I think some of this is me getting used to a new tire when my old one was worn more flat faced. So will see how this turns out. Am wondering how much air the rest of you are running in your Avons?
We noticed a smoother feel to the Trike after Avon installed. Like the fact it is for a Trike front. Dunflop was crap at 14,000 . Seeing some good reports on the Avon. Time will tell. We also started at HD tire pressure (did not notice any wandering) & just increased to 40lb per Avon guide. Will do an 1100 mile ride next week so will see how it acts.
Avon tire - twitchy ??
I have about 800 miles on the Avon front now, running 41# (started at 36, bumped up to 38) and still have that twitchy feeling, almost like buffeting the whole trike. This feel is not coming through the bars, they are stable. Dealer said the berrings were good. At first I thought it was just the difference between a new tire and the old tire with the center worn more flat. I would think if that was it, it would have improved after 800 miles. Wondering if there is an out of round issue with the new tire or a combination of the new tire and my LRS flat top windshield (buffeting feeling). Didn't notice this with the old tire & the LRS. Will talk to the dealer tomorrow. Wondering if anyone has any ideas on this??
The tire could have a high spot :Shrug: Jack up front tire off the ground , have a stationary vertical object, chair leg , or similar. Spin tire with crayon, chalk just touching tire on diferent locations. Chalk line should be constant all around.
Had a front tire with a small hop on a 2 wheeler, it will drive ya to drink 🍹.
I've only had mine for about 3000 miles, so can't comment on the longevity except I don't see any wear on it. I can comment that I like the ride better than the Dunlop that was on there before. I never asked about balancing until I picked it up from my Indie tech. He used Dynabeads. It's my first experience with them. I'm pleased with it. Caught it on sale for $99.
What model Avon tire are you using (rear on front) ?
An out of round tire will drive you crazy. I had a wheel get bent on the wife's care a few years back. Could not see it with the eye, but the tire shop finally found what it was. Jim
Ok just checked my tire. If gauge is accurate, it shows 8mm which is 10/32's I have a little over 1100 miles on this tire. So OP's measurement of 11/32 looks to be right,even though Avon site says 5mm. May depend where it is measured . I did measure deepest tread ,there are some more shallow. Avon did not specify where they measure tire.
The Avon North America site for the Avon Cobra shows the MT90B-16 to be 8.7mm. If I am not mistaken this comes out to about 10 to 11/32. My new MT90B-16 measures 10-11 32's in the deepest grooves. The 130/70R-18 size shows just 4.5 mm.
http://www.avonmoto.com/products/cruiser-touring-custom/cobra-trike
Correct! Depends on which Avon Trike tire you are talking about. The MT90B-16 (130/90B16) has deeper tread, 8.7 mm or 10/32 -11/32 than the 130/70R18 which is 4.5 mm or 6/32...
And it is a trike specific front tire in either version.
update
Dealer checked wheel bearings, stem bearings, balancing and even rear end & tires. Everything is in order. They did notice the "wandering" at speed. They called Avon and Avon will replace the tire, so I will try a second one and see how this turns out.
re- avon
Avon - Is the only tire especially made for Trikes. ( "Your going to mount it isn reverse" ) Thats great.. I hope you are going to drive in reverse as well.
